Anyone have good targets where the AIM gauge would be good to set at with the 2 stage colored alarms?
What thresholds temperature for the Yellow Warning level makes the most sense to know its time to ease off the skinny pedal a bit, and at what temperature should the blinking Red Alarm be triggered to help prohibit getting into a detrimental temperature to the integrity of the stock OEM 422280652 belt?
Anyone have settings they like, and helps keep you in a safe zone, as well as gives enough time to catch a warning if you are focused and concentrating on the path ahead of you intently, only making the occasional glance to check status?
Is there a goldilocks belt temperature zone belts "like" to operate in?
Not too Hot, not too Cold?
Does anyone wait to get a belt up to a certain temperature before harder pulls or hammering on it?
What would be good temperatures to avoid exceeding on the OEM belt?
Is there a steady temperature once you see the belt exceeding, its pretty much going to be done for once its ran that hard, and you can no longer rely on that belts integrity?
