81 - 100 of 180 Posts
What unit is the best quality AIM or Razorback. I need one and want the better of the two
Official Site Vendor
Discussion Starter · #82 ·
The Aim seems to be the hot one right now because of the many options it gives the end user. The Razorback is less money.
Aim CVT Gauge
Adjustable temp alarms that are color coded
DC volt display
One hour real time temp record display
Real-time temperature display
250786
Will the Razorback mount work with this AIM gauge?
Is the sensor hole on the clutch cover the same size as the Razorback gauge? Any chance the same wiring is compatible ?
Discussion Starter · #86 ·
Both sensor holes are .5" and both gauge holes are 2 1/16". Wiring appears close, let me know if it works.
Discussion Starter · #88 ·
Razorback gauge mounts work with the Aim CVT Temp Gauge.
I got the belt temperature gage and the mounting bracket, but the bracket isn’t the right one. The holes are way to far apart.
Discussion Starter · #99 ·
The brackets are different between 2019 and 2020. They do look similar.The 2019 RC has the 2020 instrument cluster according to my information. Post up a pic of your cluster.
Discussion Starter · #100 ·
