"... for it to be out that bad ..." This is bad? It appears to be a few degrees off. Nothing appears to be bent?Either it needs wheel bearings, Ball Joints, or you have hit and bent something for it to be out that bad.... There is no adj. for that...
If I don't see anything bent by visual inspection... What should I check first?Pictures and camera angles have been known to play tricks on stuff like that. Thats a fairly straight forward picture and it looks off a good bit for sure.
Thx bud.Check your spindle first, a arms and connections. Tug on your outer Cv just to be sure there too
