1 - 10 of 10 Posts
Need to install an accessory terminal block up front to clean up the wires running everywhere. Need some suggestions on where to put it and what others have installed.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
i use a 10 place marine fuse block i got at Cabelas, its installed behind the center dash piece with a fused 8ga wire ran from battery.
I did exact same thing as mega, for relays I just used self tappers on the steel cross brace behind the dash
does anyone have pictures of this install?
thanks for the pics that helps a lot
is your winch power ran from this block? also what gauge wire do you have running to the block?
No the yellow and blue wire on the battery is the winch. I ran 8 gauge wire from that solenoid mounted on the rear frame to the block.
Here is a pic of mine , one row is keyed power , the other row is 12 volt live
1 - 10 of 10 Posts
