1 - 1 of 1 Posts
Assault Industries carries two light mounts, a 55 degree set meant for mounting things like lighting systems to the "A" pillar part of the roll cage and a 90 degree set meant for mounting to straight vertical or horizontal bar. Both mounts come in pairs and are made from high grade anodized aluminum. Available for 1.5", 1.75", 1.875", and 2" cages.
You can see some examples of things that can be mounted with them below.
Check out the 55 degree ("A" pillar mounts) HERE and the 90 degree mounts HERE!
You can use discount code MAVF2020 at checkout!
266587
266588
266589
266590
266591
1 - 1 of 1 Posts
