1 - 9 of 9 Posts
Before I haul my 2014 Maverick XRS up to the dealer I wanted to see if anyone had a suggestion.
When I flip the 4x4 switch nothing is happening. I tried it in all gears, from a dead stop and slow speeds, and I removed the switch panel and checke to see that the switch is plugged in and right. It has worked before but this is the first time I needed it on a trail ride.
Nothing lights up on the dash display and the fronts are definately not spinning.
Since the dash indicator isn't lighting up I am assumjng the actual switch on the dash might be faulty but at this point it's a guess.
Any ideas?
Brandon
Check fuses...other than that.. if power source is good
..either a switch or actuator...??
Sent from my SCH-I545 using Tapatalk
people say water gets in from cig plug charger make sure that stays shut when washing , fuse is under driver side dash pop cover off and check ,, spare fuses in there, super easy take flashlight with u
cig plug fuse
Here is the fuse/relay descriptions....
Text Diagram Plan Design Font
1 - 9 of 9 Posts
