1 - 20 of 22 Posts
I would say yes with stock clutching. I run 30's and have the dalton kit it helped alot
With 34's i would run a clutch kit. The kit im using keeps the rpm's at 7950 with no drop like on the stock set up. Also i used the optional black and violet spring in secondary for larger tires. I have no negative affects still does 70+ mph. Also it brings the power back to stock, cause with larger tires you are going to lose on the low end like at take off. I takes more power to get moving. With the dalton kit its like i have stick tires on it. If that makes sense. Its all around a good investment if running big tires.
No i never said im running 34's reread thru the posts. Im running 30's with a dalton clutch kit.
Im on 32 terms with stock clutch, and I can still do 70 plus, 34's I would probably run something clutchwise, your pushing the issue a lil too much!
I will find out as the 34s should be delivered today or tomorrow. By the way im coming off 31 wide outlaws.
Beat on her pretty good the other day in some thick stuff and really wasn't an issue. But...... That being said I dont go out in peanut butter mud stop then try to turn the tires. When I hit that chit I hit it. Thinking bout the new qsc gen 2 but not sure yet.
Reactions: SuperATV
Ride is legit, beer doesn't even go flat. They pull well, but I would not say as good laws but the trade off is well worth it. Time will tell but so far so good I really like them and everyone knows gc is king.
Honestly I try not to use it a lot , broke one diff already and rear axles are clicking. Damn big tires lol.
but to answer yes it pulls them good . That in mind don't run out in thick ass mud and just stop. 34 is a big tire to get turning again in gumbo and that's where a new clutch will shine.
I am on 30" silverbacks and if I run in high it will slip some in the mud. everytime im in the mud I have it in low and it did fine with the epi clutch kit. im about to move to 32" rocktane tires next week. epi clutch kit is like 320
I run 32" tires with somewhat stock clutching. I got the turbo secondary and a silver ( if I remember right)epi primary spring. Never chirp or smoke a belt. And can light all 4 tires up aslong as its not thick clay. Tops out at 67 mph and holds 7850 rpm. And the last time I had my belt cover off the belt is topping and bottoming out how it should.
But everyone has there own preference
1 - 20 of 22 Posts
