Just picked up the new xrs turbo rr max and put my first 40 miles on it.
I only have a winch and Rockford stage 2 stereo installed.
While pulling another member out of the mud with my winch, about 3 seconds into the pull the winch stopped and a red battery light was solid on the dash. I turn it off and it resets and works until under load again and does the same thing.
12.8v reading when powered but not running
11.5v while cranking
14.3v while running
Under winch load it goes to 11.2v and then cuts out.
Grounds look tight, wiring is correct from dealer.
Bad battery? Bad winch? Charging issues?
14.3v while running
