Code says misfire detected - fueling disabledNeed help,
My RR is under 800 miles and it when into limp mode with code po363. Anyone else is having or had this issue?
Thanks in advance!
call the dealer you should be under warrantyNeed help,
Thanks in advance!
My bet will be a spark plug issue, fuel quality issue kind of thing. In an hour or so you can put in new plugs, I know in 800 miles you shouldn't need plugs. For $60 in plugs is nothing in relation to the pain in the ass to change.I changed the belt and it did not fix it. The code returns only when in straightaways and going more than 50 miles an hour.
Also look at the S3 racing plug change method. I did it with my tune and no need to remove the aftercooler or charge tubes. Just the rear valance and muffler.My bet will be a spark plug issue, fuel quality issue kind of thing. In an hour or so you can put in new plugs, I know in 800 miles you shouldn't need plugs. For $60 in plugs is nothing in relation to the pain in the ass to change.
Probably, but I had both off at that time as I was doing a cat delete pipe. It was a bitch to do the coil bolts with the IC above that's for sure.Meh... Pulling rear muffler and valence is more work than removing IC. Have done both. Removing IC is pretty easy (4 bolts + 2 clamps) and you’ve got clear access to the plugs
+ You can check the inside of your IC for oil contamination.
