1 - 8 of 8 Posts
Just picked up my new whip on Saturday. Should I have received two keys with this? "Normal" and "Performance". The output is definitely subdued or limited. I was wearing the driver seat belt (I heard if not wearing the power is governed). Any thoughts?
When I got the 2021 X3 XRS Turbo RR I was told that with the 2021’s you only get one key which is the performance key. I also learned that if you did not strap your harness in it didn’t go any faster than 15-17 mph
Welcome from Tucson AZ. Dealers in the past have forgotten to input the 4 digit code into the ECU. Without it, it sounds like yours. Give your dealer a shout to see if they did, or bring it back so they can check it.
2021 Maverick X3 DS
2021 owner here as well. You only get 1 key. I even called BRP directly to confirm this.
1 - 8 of 8 Posts
