1 - 13 of 13 Posts
Any ideas? Manuals say to press override and brake 3 times on power up.not working for me. Go to settings i can see reset maintenance but non of the buttons i press do anything.
There's a couple of threads about it. Recommend you do a search.
If it makes you feel any better, it usually takes me a couple attempts. The procedure does work, you just have to be spot on with it.
So you use the overide method or menu setting?mine have 99 hr,isnt supposed be at 100hr to get the message? The manual also show a light indicator but i dont get nothing yet.will wait to 100 to see if im able to reset it.
I had mine pop on at like 95 hours, had the dealership reset it when they were doing warranty work
Settings .. reset maintenance....hold the middle button on the d pad....if it comes back it is a known issue and you will have to get it taken care of at the dealership
Discussion Starter · #10 ·
Exactly,the same as resetting stats,i get a beep when done on stats nut not on maintenance,it goes to exit but return back on next cycle
Discussion Starter · #12 ·
Problem was cluster needed reflash an update.now convince them that the p0363 is the flywheel.
1 - 13 of 13 Posts
