Fox has not yet provided any information regarding 2021 suspension settings for the "Fox Tune." 2020 specs definitely do not carry over to 2021, as on a brand new machine, the overall spring length of 31" in rear makes for a 13" rear ride height.
So, my plan is to add preload until the ride height is about 15.5", then the crossovers to about 1.5" and 2.5" front and rear respectively as per Shock Therapy's suggestions.
What would can you recommend as to the rebound, high speed compression, and low speed compression?
Has anyone with the same model played with suspension settings and found a good mix of settings for trail riding?
