Was motoring down the trail tried to climb a mild hill when felt like the clutch/belt is slipping, basically the engine was revving higher than normal and the buggy did not move as usual. Made it back home. Removed the CVT cover and found the secondary clutch's small plastic bushing half broken off and laying at the bottom of the clutch case. See pic. Found the other half still in clutch housing, but noticed the other two completely missing. Where did they go?
What parts or tools I need to fix this? Is this a common problem?
The buggy has 2000 miles. zero problems until now.
Thanks
Thanks
