1 - 11 of 11 Posts
So my SXS ( 2020 Maverick X3 XDS Max Turbo RR) clutch wont engage until 2500-2700 RPM, what would be causing this?
has it ever been lower?
2020 X3 X RS RR
I just purchased it and was told by a can am tech that normal rpm is 1650 plus or minus 100, and I’m getting 2500-2700 so I didnt Know if that’s normal or not
My 2020 XRS engages around 2100-2200 or so. No way 1650 is right. They idle at 1500 or so.
If a previous owner changed the primary engagement spring, that will change things.
Discussion Starter · #7 ·
well thanks for the input. I’m not super familiar with anything about it. Another question I have is when I take off the rear end clicks and clanks a lot. Is this normal? The rear end is locked
2020 X3 X RS RR
Def normal for many reasons and nothing to worry about. Lots of things clank, clunk or whine. These CVT drives will drive you nuts if you spend any time at all at 4500-5500 rpm. Totally normal as well even though you will think it is defective.
Discussion Starter · #9 ·
perfect. Last question I have. When I put the machine into reverse and let off the brake it starts to go backwards without hitting the gas.
2020 X3 X RS RR
You need to open your clutch housing and get familiar with your car. Forward engagement at 2500+ and reverse moving at idle, you have maintenance issues at least. Did you buy this new? How many hours or miles on it? What is your idle speed?
Maybe a cleaning and new belt is all that is needed.
Buy the online manual and get intimate with that bitch....
Discussion Starter · #11 ·
i did not buy it new. There’s 500 miles on it, I’ll check my idle speed and I have the manual and that thing has been a life saver so far!
1 - 11 of 11 Posts
