1 - 20 of 238 Posts
Has anyone been able to get into a 2020 and see if the intercooler or airbox will bolt up to our earlier models? Got a look at a 20 today and both those components are definitely larger and improved, Pulled the air filter out of the box and the inlet/outlet are substantially improved but unfortunately couldn't get any further on the showroom floor to see if they'll be compatible.
I'm patiently waiting for the airbox too. I'm thinking the inlet hose to the turbo will be the issue, if any.
I heard the inter-cooler won't bolt up, But I will NOT cite my source! Tim
Intake/airbox is different from previous models and intercooler itself is bigger. Confirmed it with EVO bc I wanted to order the charge tubes to add a BOV and they aren’t compatible
I received the 2020 air box. Much bigger than the 2019 version. I didn't order all the parts at once so I could see what other parts would be needed. As you can see the inlet and outlet are much larger. The box itself is around 120 dollars and it comes with a filter element.
This should be the list of parts you will need. I think some clamps can be used from the original box, but I included them just to make sure I have enverything I will need. I will confirm the final parts list once I have everything installed. So its about 215 total, but it does include a new filter element.
Airbox - 707800859 - 119.99
Hose to top - 707800861 - 15.49
Clamp - Hose to top - 293650096 - 2.54
Hose to turbo - 707800856 - 31.99
Clamp - Airbox side - 514052924 - 11.49
I would recommend holding off buying this until I have the install complete and verify that there are no fitment issues.
EDIT. Fixed a typo on one of the part numbers and confirmed that everything fits.
251472
251473
251474
2017 X3 max XDS
I had wondered if they were going to open th end of the airbox to a larger size knowing it was a severe restriction point to the turbo. I already changed out my air box to a UMP and a big improvement in throttle response and no hesitation.
Air box
707800859​
119​
Hose to turbo
707800840​
32​
Clamp air-box side
11.49​
Emission Breather
273000234​
11.49​
Clamp Turbo Side
3.49​
Larger intake duct to top of machine707800856
26.17​
Intake side clamp
293650096​
2.13​
Intake side clamp
514052924​
8.77​
214.54​
View attachment 251472 View attachment 251473 View attachment 251474
Thanks for sharing. Looks like a lot more airflow with the 2020 box.
If that is the case there should be a different intake boot from the turbo to box for the smaller turbo on the non-RR models.
I didn’t think of that. I’m glad you did so I could make sure! I checked and the part number for the intake boot is the same for both models.
I don’t think the inlet side of the RR turbo is any bigger that the standard model.
2018.5 Can Am Maverick X3 XRS
Interested in the outcome from Ledfoot, I may want to "modificate" mine too!!!
1 - 20 of 238 Posts
