1 - 1 of 1 Posts
Setup for DP4 and BITD Rally Class ($55,000 OBO)
Chris Blais
[email protected]
760-961-9127
Alsup RD front upper and lower a-arms $2500
Alsup RD Rear trailing arms $2800
Alsup RD Radius rods $ 1200
ZRP rear Knuckles $2000
ZRP Front Knuckles $ 2000
KMC 15” wheels $500
New Kenda Mastodon HT 32” tires $1000
New Spare Tire on Car $250
Race Prepped Axles $500
Baja Designs Onyx 10” shock tower light $1000
Baja Designs Rear S2 amber light $300
Mastercraft S2/4 seats and custom brackets $1000
BRP Seat frames $350
Impact 5 point harnesses $600
Full KWI Clutch treatment, Full Floating Secondary and Dialed in Primary with weights $2000
PCI Helmet Pumper $400
PCI Full Radio/ Intercom and dash setup $2000
Carbon Fiber Center Console with Main Power Cutoff Switch $300
Cat Delete Header $500
Ported head/ Race Valve Job/ Camshaft $1500
Dynojet with custom Whalen tunes $400
Oil Cooler $400
Larger front TCP radiator $800
Shock therapy steering rack $2000
Engine and transmission rebuild 500 miles ago
250 miles on Front Diff
S3 full weld in gusset kit $500
Custom gussets in problem areas $1000
SF Raceworks custom Chromoly cage $2500
SF Raceworks professional Mill Spec wiring with Switch Pro $4000
Custom tuned shocks by UTV Shocks.com $2500
Eibach Springs $2000
Eibach Rear sway bar with custom links $400
Aftermarket skid plate $1000
Quick release steering wheel $200
Sparco Steering Wheel $200
Hostyle Window Nets $400
Automatic Fire suppression system $800
2 Fire Extinguishers $200
Dirt Specialties Doors w/ secondary door latch $800
Custom door bags $400
Stock Fuel Tank with Dry Break System $500
Seal Saver Shock Spring Covers $80
Sector Seven Mirrors $400
Ipad Holder $120
$44,400 in accessories
Weld in chassis gussets labor 100 hours
Contact:
Chris Blais
[email protected]
760-961-9127
Wheel Car Tire Land vehicle Vehicle
Vehicle Motor vehicle Automotive tire Automotive lighting Hood
Vehicle Automotive tire Hood Motor vehicle Car
Vehicle Motor vehicle Steering part Speedometer Gear shift
Tire Wheel Hood Automotive tire Vehicle
Vehicle Automotive tire Motor vehicle Wheel Automotive design
Tire Wheel Land vehicle Vehicle Automotive tire
Tire Wheel Automotive tire Motor vehicle Tread
Automotive tire Automotive lighting Motor vehicle Vehicle Tire
Tire Wheel Car Vehicle Automotive lighting
1 - 1 of 1 Posts
