I have a 2020 x3 turbo rr with smart lock. So the service smart lock came on the other day when I was stuck in a hole. Here is how it all played out and what I have tried
I hit a mud hole and had to put it in diff lock only had the passenger side tire was pulling. Got home jacked it up off all 4 tires and started trying to trouble shoot. All the axels feel fine, put it in smart lock you can hear the drive shaft click in but once you hit the gas no movement in the front tires. Next I put it in diff lock, I hear the front diff click in mash the gas and only the passenger side tire pulls. As soon as I spun the driver side tire by hand in diff lock you could hear the diff disengage but still showed it was engaged on display. So I disengaged it and then put it back in diff lock, went to the passenger side spun the tire and it spun the with the back two. I’m trying to figure out what it is before I snatch the diff out. Any help would be greatly appreciate
