21 - 22 of 22 Posts
Discussion Starter #21
update to the can-am engine light.. I figured the problem out with out a code reader but can-am and like most ecm driven engines even after you fix the problem you need to clear the codes...code read misfire and i already replaced the coil that was weak through reading the spark plugs and checking resistance on coil...local dealer cleared codes no appointment necessary at this place... I'm still going to get a code reader...
21 - 22 of 22 Posts
