61 - 64 of 64 Posts
I'm having the same problem with the EVO's stage 5 X85 tune. They promote 27 pounds of boost at sea level and I'm not passing 22..
I have checked for leaks and tried a different wastegate but nothing..
Any ideas ?
The Maptuner X will only read a max 22lbs no mater what. Everyone needs to get the dash reflash to show boost or an aux gage for boost.
it is not no matter what....
they just need to correct the programming for the map sensor being used
like a 4 bar can read 45psi boost and 3 bar can read 29psi
also you can use math to get the correct boost even when the program is not correct
22 psi with a 3 bar sensor is actually 29psi
20psi should be about 27psi using a 3 bar sensor
and 2.5 bar programming
61 - 64 of 64 Posts
