41 - 48 of 48 Posts
Pressure
The maptuner doesn't care what kind of turbo it is. It just needs the correct boost and that is controlled by the waste gate actuator
The map tuner reads voltage from the map sensors. If the maptuner thinks there are 2.5 bar map sensors installed and they are actually 3 bar map sensors, the boost reading in the maptuner is not going to be accurate.
I know you said you leak tested it, but sure sounds like a leak to me. When i had that tune i had crack at like 12psi at 4500ft elevation. Weird. I bet that turbo is spinning super fast.
41 - 48 of 48 Posts
