(P-Ccode) P0107
(Module) ECM
(Description) Manifold Air Pressure Sensor voltage too Low
(Cause) Damaged sensor, damaged circuit wires, damaged connector or damaged ECM pins, ECM voltage supply Low
(Action) Make sure sensor connector is fully inserted. Measure voltage between harness connector pins 1 and 4 . (Expected value: 4.8 to 5.1 volts) Measure resistance from connector: ECMA-H3 to MAPTS-2 (Expected value: < 2 ohms) Measure resistance from connector: ECMA-G4 to MAPTS-3 (Expected value: < 2 ohms) Measure resistance from connector: ECMA-H2 to MAPTS-1 (Expected value: < 2 ohms) Measure resistance from connector: ECMA-B4 to MAPTS-4 (Expected value: < 2 ohms) tmr2013-025
(P-Ccode) P0113
(Module) ECM
(Description) Intake Air Temperature Sensor 1 circuit High
(Cause) Damaged sensor, wires shorted to battery +, ECM voltage supply too High.
(Action) Make sure sensor connector is fully inserted. Measure voltage between harness connector pins 1 and 4 . (Expected value: 4.8 to 5.1 volts) Measure resistance from connector: ECMA-H4 to ATS-1 (Expected value: < 2 ohms) Measure resistance from connector: ECMA-J4 to ATS-2 (Expected value: < 2 ohms) 4 tmr2013-
Reseat the MAPTS (
Manifold Air Pressure/Temperature Sensor) highlighted in blue on the picture below…
