UTV INC CAN AM MAVERICK OPENING REMOVABLE DOORS
** THESE WILL FIT THE 2014 MODELS !! ** UTV INC IS PROUD TO RELEASE A DOOR DESIGNED SPECIFICALLY FOR THE CAN AM MAVERICK. NOT A COMMANDER DOOR THAT IS "GOING TO WORK" BUT DOES NOT MATCH ANY OF THE MAVERICK BODY LINES OR PANELS. THIS DOOR IS BENT AND DESIGNED TO FLOW WITH THE BODY OF THE CAN AM MAVERICK AND GIVE YOU A FULL DOOR FOR OPTIMAL PROTECTION. STEEL TUBING CONSTRUCTION. TIG WELDED. ALUMINUM PANEL WITH STAINLESS BUTTON HEAD ALLEN HARDWARE. THE UTV INC OPENING CAN AM MAVERICK DOORS WILL WORK WITH EITHER THE OEM (STOCK) OR MOST AFTERMARKET ROLL CAGES. DOORS ARE FULLY ADJUSTABLE FOR THAT EFFORTLESS OPENING AND CLOSING THAT UTV INC IS FAMOUS FOR. THE UTV INC DOORS ARE REMOVABLE WHEN OPENED PAST THE LOCKING TAB BY SIMPLY PULLING THE HINGED PANEL OFF THE FRAME. THESE DOORS ARE SOLID AND WILL TAKE A BEATING. DOORS ARE POWDER COATED SATIN BLACK FOR A LIFE LONG DURABLE FINISH. STOCK SEATBELTS WILL NOT WORK WITH THESE DOORS, AN AFTERMARKET RESTRAINT SYSTEM MUST BE USED.
