Hello i have performed my maintenance on the mav. Oil change front diff, back diff, engine etc. But i cant get the "Maintenance required" to stop coming across the screen at startup. I have followed the operators manual step 3-9 in under 5 secs but it still will not go away. yes the key was tried in both positions. No the engine was not running, Yes i shut off the key and waited for the display to turn off at the end of the programming sequence. I noticed if i hold the brake on for longer than 15 sec the light will NOT come on like it should. does your light come on if brake is pressed for longer than 15 secs. is there a switch in the master cylinder by chance.
thanks for your help
