Standard Features - Maverick
Industry-Leading Performance
Precision-Engineered Handling:
Rider-Focused Design
Color and Engine Option
Yellow - 1000
Package Option
X RS Package
Added Features
Yellow & Black with X-Package Graphics - 1000
- 101-hp Rotax® 1000R V-Twin engine with high-flow dynamics
- Intelligent Throttle Control (iTC)
- Continuously Variable Transmission (CVT) with Zylon†-reinforced belt
- Dual exhaust
- 10-gal (37.8 L) fuel tank
- Mid-engine layout for mass centralization
- Double A-arm front suspension with 14 in. of travel
- Front and rear FOX PODIUM X Performance 2.0 HPG piggyback shocks
- Torsional Trailing A-arms (TTA) independent rear suspension with 14 in. of travel
- Visco-Lok auto-locking front differential
- 13 in. (33 cm) of ground clearance
- Front and rear dual 214-mm ventilated disc brakes
- 27-in. (68.6 cm) Maxxis Bighorn 2.0 tires
- 12-in. center-less cast-aluminum wheels
- High frame rigidity
- High-strength, 200-lb (91 kg) multipurpose rear rack with LinQ quick-attach system
- 2-in. (51 mm) diameter, high-strength steel, ROPS-approved cage
- Adjustable driver’s seat and tilt steering
- Passenger handhold and grab bar
- 1,928 cu in. (31.6 L) of cockpit storage
- Digitally Encoded Security System (D.E.S.S.) anti-theft system, with 2 different keys
- Multifunction digital gauge
Yellow - 1000
Package Option
X RS Package
Added Features
- Front and rear FOX PODIUM X Performance RC2.5 HPG piggyback shocks with dual-speed compression, rebound and threaded preload adjustments
- 12-in. aluminum beadlock wheels
- Analog / digital gauge
- Custom steering wheel with brushed-aluminum center part
- X-package seat trim and graphics
