21 - 29 of 29 Posts
The new Commanders come with the Visco/QE front diff now, I know people are saying the Maverick doesn't have the QE diff but i would wait till the final production machines before making that conclusion.
My biggest worry is the damn fly by wire throttle cutting power if its airborn like the commander does now. I hope the fixed that on the maverick. If not then all this new power just means a bigger lawn dart at a higher speed.
My cousin was doing a donut on his commander, it cut the power flipped and broke his hand into..... Not an option I want on mine.
I would get rid of the stock Roll Bar, add a Bed delete, and put a shallow aluminum bed in there... then she would look like a Duner for sure...I want to test drive one at Glamis for Hollow Weenie...
It's only 2" less, but in stock form it's 64" wide
Same as the Commander with 2" wheel spacers all the way around
DIMENSIONS: L x W x H (in)118.8 x 64 x 74.2 in.
L x W x H (mm)3,017 x 1,626 x 1,885 mm.
Wheelbase: 84.3 in (2,141 mm).
Ground Clearance: 13 in (330 mm).
Dry Weight: 1,297 lb (588 kg).
Rear Rack Capacity: 200 lb (91 kg) with LinQ™ quick-attach accessory system.
Cockpit Storage Glove Box: 4.5 gal (17.2 L)
Under driver's seat: 3.5 gal (13.1 L)
Center console: 0.3 gal (1.3 L).Fuel Capacity10 gal (37.8 L).
Dimensions say 118.8 for length, can someone explain where this is measured from? I have a toy hauler and a commander will not fit in a 10ft box. bed sticks out to far. Just wondering if this will fit in a 10ft box being that the rear is designed a little different.
That should be total vehicle length from front to back imo.
21 - 29 of 29 Posts
