Hello, had a bad cv axle and bearing that was replaced and after my first ride noticed the brakes weren’t working which was from a loose axle bolt causing the wheel to wobble. Took the maverick to the dealer and asked the check the bearings. They said everything was good but the axle nut was loose.
I noticed this gap at the knuckle where the cv axle connects on the side the went bad and no gap on the opposite side. This is the front end. I am attaching some pictures of the bad and good side.
is this gap normal?
is this gap normal?
