21 - 27 of 27 Posts
I highly doubt the ECU has to be “sent” anywhere. Enabling the intercooler fan should be firmware controlled function. If you can send it to a tuner to enable it, what could they do at their shop that couldn’t be done from flashing it from the PV3?
Not sure but was told it has to be sent in to bench flash it. Pv3 will not do it. I had to chase down this answer because some people say you do and some say you dont.
Interesting.......I’ll call Dynojet and see what they have to say. How were you able to get that answer?
The issue with dynojet is it will not let you flash a non compatible tune file in, to get the fan control you need a tune from a different model machine so basically it’s a different operating system or a segment change to enable the fan control. I tried to get some answers from dynojet just on flashing different model tune files into different machines and the software wont allow it. I tried it on mine, just grabbed a stock tune from a 17xrs loaded it on the tuner and it wouldn’t even show up in the list of tunes to flash on the unit from the flash option.
Could someone post a PV_Info.txt or stock file for one of these machines I would like to take a look at a one.
21 - 27 of 27 Posts
